I need to comunicate an ADS1278 with a PC for serial port using SPI interface
Hello.
I am new in this forum and I dont have so much expirience using labview.
I am tring to comunicate a ADS1278 which use a SPI interface for comunication.]
It device is working as a master (it generated the SCLK and FSYnc) and send 24 bits per channel
and I am using 7 channels for that reason It is sending 168 bits per cicle of Fsync period.
And the SCLK clok will be runnig about 1MHZ.
I am really dont know how to do it.
Thanks a lot for your time and help
(3,243 Views)
Dear,Regarding the ADS1278 board, I don´t have further information about it.The USB-8451 has the NI-845x driver that supports I2C and SPI. Even if the NI-845x supports only NI hardware, I suggest you refer the NI-845x Software User Manual documentation. In this documentation you will find an overview of SPI  as well as detailed information about API.https://www.ni.com/docs/en-US/bundle/ni-845x-hw-dsw-getting-started/resource/371746e.pdf RegardsJailton – NIB – SR 1245087
(3,211 Views)
