I need to design Front panel like this
I need to Desging my front panel design like this
Help me to find out this !!
I
Message 1 of 12
(4,124 Views)
Hi saran,
looks like a tab control inside of another tab control. Below those tabs is a string indicator and some buttons.
What have you tried?
Where do you have problems with?
Message 2 of 12
(4,120 Views)
Tab inside tab is no Problem.
But the Bottom one is not Buttons thats also Tab Pages
Message 3 of 12
(4,107 Views)
Hi saran,
so you already know what you need? Then why do you ask?
In your first image they look like usual System buttons to me. I would use buttons to switch a tab control with hidden tabs…
Btw. stacking 3 tab controls with several pages doesn't sound like a good UI design approach to me. But that's just my opinion…
Message 4 of 12
(4,104 Views)
"I would use buttons to switch a tab control with hidden tabs…"
This buttons to switch a tab " can you give me any sample vi
Message 5 of 12
(4,099 Views)
Hi saran,
you use those buttons to write a new value into a local variable of your tab control.
Do you really need example of how to write a value into local variables? After more than 100 messages in the LabVIEW forum?
(If the answer is YES: please take the free online courses offered by NI on their website!)
Message 6 of 12
(4,097 Views)
Hi  GerdW,
Thank u for you kind reply,
Here is the sample file for Button to control Tabs.
i just asked better Way as you are experience (10,652 messages)
Message 7 of 12
(4,063 Views)
Hi saran,
that's a fine solution using the event structure!
One remark: as of now you use your buttons like radio buttons (only one selection at a time allowed). Why not use real radio buttons?
Message 8 of 12
(4,054 Views)
I dont know how to do that !!!
Message 9 of 12
(4,048 Views)
Hi saran,
- Put a radio button on your front panel.
- replace the existing buttons by buttons of your choice to get the look&feel you want.
- add as many buttons as you need to this radio button
What's the problem with theses easy steps?
Message 10 of 12
(4,045 Views)
