I need to find an algorithm which can calculate the shortest path through a certain number of points in space
In this case he probably doesn't need to return to the start point, so the problem is simplified:
http://stackoverflow.com/questions/7763432/what-is-the-difference-between-travelling-salesman-and-fi...
Also, the number of points is probably small, so the computation time should be quite quick for the shortest path.
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 11 of 17
(2,315 Views)
Yes, the "Travelling salesman problem" is exactly what i search for. Thank you very much. Now i only need to study hard....!
Message 12 of 17
(2,280 Views)
Brute-force will be sufficient for the movement of a camera.
Jim
Message 13 of 17
(2,270 Views)
I don't think brute force will be applicable. With only 10 points in space i must check (10-1)!/2=181.440 different paths.
Message 14 of 17
(2,231 Views)
Hi FM,
with just 180k possible paths you can employ brute force…
Message 15 of 17
(2,225 Views)
It was only an example, if the user begin to add points where to move the camera (my software must be programmable) i fear i can get stuck in the optimization routine.
GerdW ha scritto:
Hi FM,
Message 16 of 17
(2,223 Views)
Consider your requirements.  Do you need absolutely the shortest path, or an "efficient tour" (i.e. "one of the shorter paths")?  Do you have a fixed starting point, or is it arbitrary (in which case there may be different "shortest paths")?  Can you visit a point more than once on a tour?
I suspect that if conditions are relaxed a little, adding a new point becomes computationally much simpler.  For example, if the sequence p(i) (where i goes from 1 to N, number of points) is your current "good" path, take your new point, put it between successive p(i) and p(i+1), and see which of the N paths is shortest.  Note that this will (almost certainly) degrade if you do it multiple times, but to add, say, 3 points to a tour of 10, I'd guess it wouldn't be too bad.
Bob Schor
Message 17 of 17
(2,195 Views)
