I need to find an exe file to run it from labview
sorry, that previous message should have read I am NOT experienced in working with the registry.........................(or typing either it would appear)
Message 11 of 16
(957 Views)
When a program is installed information as to its installation path is (usually) written to the registry. One place that you can find this information is in the HKLM/Software hierarchy. When your program gets installed a new key (folder) should be created in that tree. Sometimes you'll find a "Path" key within this subtree. Sometimes the path is stored in the "Default" key for that subtree. The only way to tell is to actually look.
Another location where this information can be found is in the HKCR\Applications hierarchy. Each application has its own subtree. There you will have a shell\open\command and the "Default" value will provide the full path to the application. Attached is a screenshot of what my registry looks like for, say, Firefox. If I wanted to read this registry value in LabVIEW I would do this:
Message Edited by smercurio_fc on 09-01-2008 02:58 PM
Message 12 of 16
(939 Views)
Hi there
if i'd be the user it would be OK for me to manually supply the path to the desired application, e.g. by a file dialog (i do similar things each time i configure e.g. web browsers, mail clients, IDEs etc..). If the LV app stores the path in a file it would ask me only once.
just in case the folder of the app is in the systems search path you do not have to supply the full path of the app to run it.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 13 of 16
(930 Views)
There's on more location in the registry where you could look:
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\<Appname>. If the application is listed there you'll find the path in the default key.
Message 14 of 16
(926 Views)
Hi Dylan,
What everyone is saying would seem to be the way to go either:
1) Read the location from the registry if it creates a registry key on installation.
2) If not then creating a one off prompt where they select the location of the executable and then save this information to a configuration file.  You could perhaps automatically set the expected location (presumably c:\Program Files ...) and if it isnt found there then prompt the user.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 15 of 16
(898 Views)
Thanks to you all for your help,  I have searched the registry carefully, but I do not think the program does create an entry there which means I cannot find it there.  I think the best option is to look initially in its expected location and if not found open a dialogue box for the user to locate the software.  Thanks again for your help.
Message 16 of 16
(894 Views)
