I need to have more than one front panel for one block panel
Message 11 of 14
(642 Views)
Accepted by SaranVenkateshS
maybe this would be an option?
https://decibel.ni.com/content/docs/DOC-24648
Of course, only if you want dynamic subVI calling. But the main thing to try is the two "main" VI running in parallel, with shown front panel and with some intercommunication between them...
Message 12 of 14
(641 Views)
hi Blokk,
              thank you ... this one may helps me lot
Message 13 of 14
(636 Views)
You are running into the situation where you need to modularize your code.  You should have a control process/VI and a vision process/VI.  They should be completely separate and run in parallel.  Use Queues or User Events to send any shared data back and forth.
GCentral
Message 14 of 14
(596 Views)
