I need to insert a number into an array for every 15 mins continuously..
I need to insert a number into an array for every 15mins continuously..and the array need to hold all datas for example in 0th position i insert a value 10 by 10.00am, after that at 1st position i need to insert 11 by 10.15am, next at 2nd position i need to insert 12 by 10.30am and so on...how this can be done
Can anyone help me in this...
Message 1 of 9
(4,151 Views)
Start with the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
When you are ready to start programming, you'll be looking at Build Array, shift register, while loop, and elapsed time Express VI.
Message 2 of 9
(4,150 Views)
Hi cgk -
I've thrown together a fairly simple approach to what I believe you are asking for. This kind of approach you will learn in the basic training courses for LabVIEW. So, if you wish to learn more about  what is going on, I suggest you seek further training.
I haven't included any conditioning on the number display; have used only 5 seconds as the time compare; and the loop will run as fast as it can until the stop button is pressed. Also, the array won't be displayed until you press stop... Comments included.
However, here is something you can start working with for now. Enjoy. 🙂
David.
Message 3 of 9
(4,116 Views)
Problem description seems incomplete. Where is the value to be inserted coming from?
Message 4 of 9
(4,099 Views)
Iam Sick of this code.... i hope you can get some idea on this, it continuously loop . but it can give an output every 15 mins. as you said  0th position i insert a value 10, 1st position i need to insert 11. try to evaluate and do what exacly waht you want..
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 5 of 9
(4,050 Views)
Hi Syrpimp -
A good idea. You probably don't need the While loop here, as the For loop will run its course as per the number of required iterations.
To go the other way, you could get rid of the For loop and place all shift registers on the While loop and use the loop iteration number instead.
Of course, that depends on how the original poster inteads to implement his code.
One thing I will say is, you need to be careful on using the Wait vi - it will hold that For loop up for 15 mins, thereby removing any focus on the Front Panel. This means you can't stop the loop or program until the For loop is finished (No.of.Data x 15mins), or perform any other action.
Message 6 of 9
(4,032 Views)
I'm glad to here those point from you David, thank you for boosting those out... and I will  note on those.  you will absulotely determine i am a rookie by that code.   Smiley Happy  lesson learn.
syrpimp
Message 7 of 9
(4,023 Views)
The Quotient Remainder Function is kind of pointless when you divide by 1.  The remainder is always zero in that case.
Message 8 of 9
(3,992 Views)
Long waits in inner loops are a bad idea, because they block any reasonable user interaction. Use the timeout case of an event structure instead, or poll with the elapsed time express VI.
Message 9 of 9
(3,984 Views)
