I need to make this reading table urgnetly!!!
Hi Rafael
I checked with my old version 5 manual, the Get Date/Time String is in there. The Build array is there also but it looks slightly different, you have to right click on the top element and select change to array. If you need to keep the data as numeric you can use a second shift register and build a second numeric array.
Ian
Message 11 of 21
(1,556 Views)
IanW,
I did what you said.I found the functions ,etc.
I did the same program in labview 5.1 but the table doensn't junp the lines.
I want each data corresponding with time and date.
But the table dosent't jump the line.
I am sending the doc.
Help me!!!
Rafael -Brasil
Labview 5.1
Message 12 of 21
(1,545 Views)
I forgot the doc.
Here it is.
Help as soo as possible.
How to jump line,the example you show doesn' t do the same thing.
Rafael
Message 13 of 21
(1,544 Views)
Hi Rafael
Did you wait for 60 seconds to see the table update. You could change the 60 constant to 10 to speed things up for testing.
Ian
Message 14 of 21
(1,536 Views)
IanW
I waited 60 seconds but didn't jump the lines.
Data change each second in the same line.
I need  a value for ecah channel for each date and time.
At the moment what i need it is jump the lines.
Any suggestion??
Rafael
Message 15 of 21
(1,531 Views)
IanW,
I 've just played the labview with that vi,and the table doesn't update in the following lines.
I can ' t do jumping lines.
Help me!
Sorry by my english but as you know i am in a hurry.
Rafael
Labview 5.1 - Brasil
Message 16 of 21
(1,515 Views)
Rafael,
Your 'Stop' boolean is wired to "Continue if True" Try inserting a "Not" primitive.
I'm guessing that you may also be using the "Run Continuously" button in the toolbar rather than the "Run".
Message Edited by Donald on 09-01-2005 05:06 PM
Fading out. " ... J. Arthur Rank on gong."
Message 17 of 21
(1,501 Views)
You are correct.But i don't think that it is the cause of the table which doesnt't update jumping lines.
I am running the program as test with run continuos,but i will do this.
I wait more help.
Rafael - Brasil
Labview 5.1
Message 18 of 21
(1,493 Views)
Hi for all
Many answers but i didn~t arrive at the big point..rs
Help me guys...
I am doing some tests with the vibut i need some help.
Attention that i use labview 5.1.
Rafael - Labview 5.1
Brasil
Message 19 of 21
(1,486 Views)
Hi Rafael
I've found a computer with Labview version 5.0 it doesn't have tables so I've used a normal string array indicator. Using version 5.0 I've remembered that that you have to be very carefull when making connections to the edges of loops and structures, make sure the little box is flashing when you connect with the wiring tool. Double check all you connections or have a look at the vi attached (version 5.0)
Ian
Message 20 of 21
(1,484 Views)
