I saw the diagram with the pin numbers on the CB-68LP connector block, but I need to know what each of those pins mean if I'm connecting it to a PCI-6023E DAQ board as well as a H5784 Photosensor?
We are acquiring light readings from the H5784 photosensor and analyzing them in LABVIEW. We are using the light level readings from LABVIEW to turn off or on a Masterflex pump using a relay based on the light levels.
(3,625 Views)
Check out chapter 4 or the 6032E DAQ manual entitled "Signal Connections". It gives pin-out numbers that will correspond to the pin numbers on the CB-68LP.
Tim
(3,624 Views)
Hi!
I use PCI-6229 DAQ-card. Is there any "Signal Connector" chapter for that card?
(3,366 Views)
This pinout is in the M Series compiled help file (chm) which you can find here:
From the tree view dig down to "Specifications and Device Information >> NI 6229 >> Pinout"
(3,363 Views)
