11-23-2004 12:57 AM
11-23-2004 02:26 AM
Tc@labView wrote:
I tried numerous ways that some people suggested in this forum but did not succeed in having the LabView Data folder created somewhere else than in My Documents when running a built LabView application. Changing the target destination folder did not help at all. A member suggested to put some line like " defaultdestination = ..." or so into the build file, but I did not know where exactly to put such a line. That folder created is particularly anoying for people who don't normally use LabView but are only using the application. Please let me know when you LabView Experts out there have found a way to eliminate or relocate the creation of that folder at application startup.
Thanks a lot.
Tim, Van
11-24-2004 12:54 AM
11-24-2004 01:43 AM
Tc@labView wrote:
Franz,
whenever I build an .exe file through the application builder I get a file with an icon that looks like a notepad file but has a gear on it. It has the same name as my application and usually does not contain any more than the name of the application after it is created. Is this the ini file you were mentioning earlier? I tried to add the defaultdata... = ... into it but did not notice any change. Did I miss something? The Default seems to be set to C:\program files\national instruments\labview 7.
Tim
11-24-2004 02:07 AM
11-24-2004 03:57 AM
11-24-2004 02:09 PM
