I struggle with this every time I have a new install... Palette configuration... it's embarrassing
I can at least make it simple to ask- here's an imgur link:
http://imgur.com/u6wnZGU
the way my current right click palette appears is on the left in red, and I want it to appear like the one in green on the right- I'm trying to get my install at home to match my settings at work- and it has been so long since I did a new install I totally forget where these config options are- I've played with it a bit and at this point im more frustrated than I am embarassed to ask haha
There's gotta be some folks on here that remember - kudos to those who post up! thanks!
-pat
(2,552 Views)
All you need to do is use the pin icon. Basically pin the pallette and then the customize button will appear at the top of the pallette.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,526 Views)
Accepted by plyons.gks
Another reason I always backup my LabVIEW.ini file for each version I use.  On a fresh install, I just put that ini file with the LabVIEW.exe and all of my settings are there.
(2,501 Views)
yes.   exactly what I needed to learn here- thank youuuuuu crossrulz!
-pat
(2,489 Views)
Just as a side note, I'm going through this same thing right now since I just had my computer wiped.  Glad I keep those config files in a nice safe spot.Smiley Happy
(2,481 Views)
