I use a VI to do an operation in which there is shift register (while loop), can I pass the last value of shift register?
I use a VI that will do an operation in while loop in which there is a shift register.
I desire that when i push botton stop the VI stops execution and the last value of shift register is passed to a indicator. It's possible to give the last value of shift register of a output value of VI maybe assocating to it an indicator out of while loop?
(2,558 Views)
I think you mean like this?:
"Everything should be made as simple as possible but no simpler"
(2,549 Views)
