How to add multiple inputs in sequence in a for loop
Flow sequence Diagram:
(A+1=B follow by -> C+1=D follow by -> E+1=F) in a FOR LOOP and the next loop will be,
(B+1=X follow by -> D+1=Y follow by -> F+1=Z)
It will loop till loop count ends.
Thanks in advance for the help!
cheers!
Message 1 of 22
(4,632 Views)
I don't understand what you are trying to do with your description.  How many times do you want this for loop to run?
Whatever you are trying to do, it sounds like you will need shift registers.
Message 2 of 22
(4,628 Views)
If by "flow sequence" you mean "chart flow", you could draw it and post it to explain what the problem is 🙂
Message 3 of 22
(4,621 Views)
Hi YMC,
how will it continue? What comes after F+1 = Z?
Mike
Message 4 of 22
(4,598 Views)
thanks for all your advice. i have attached a picture for easy reference. hope it will make understanding easier. Untitled.jpg
Message 5 of 22
(4,563 Views)
Hi YMC,
do you mean like this?
Mike
Message 6 of 22
(4,560 Views)
hi Mike,
Thanks for your example. it was indeed helpful.
Is there anyway to make sure A, B and C runs in sequence. A first, followed by B and then C.
Message 7 of 22
(4,529 Views)
Hi YMC,
yes! Please explain how you need it. I think you don't need a workflow in this simple example. 🙂
Mike
Message 8 of 22
(4,526 Views)
Hi Mike,
C follow by B then A. This sequence will then loop in the 'for' loop accordingly to the loop count.
best,
MC
Message 9 of 22
(4,519 Views)
Hi YMC,
use the "normal" dataflow and please explain how you use it. It sounds like you use local variables.
Mike
Message 10 of 22
(4,509 Views)
