How to add multiple inputs in sequence in a for loop
This will do:
A + 1, then
B + 1, then
C + 1, then repeat until stopped.
Is this what you are after????????
"Everything should be made as simple as possible but no simpler"
Message 11 of 22
(1,862 Views)
Hi Lucither,
thanks for your advice, but i intend to 2 of +1 and 1 of -1.
Hi Mike,
there will be 3 variables. 2 of which i intend to add 1 and 1 to subtract by 1.
best,
MC
Message 12 of 22
(1,854 Views)
This will first:
A - 1, then
B + 1, then
 You can play around with the order to suit your needs.
Message Edited by Lucither on 03-23-2010 08:12 AM
Message 13 of 22
(1,848 Views)
YMC wrote:
Hi Mike,
C follow by B then A. This sequence will then loop in the 'for' loop accordingly to the loop count.
best,
MC
But your sketch shows A, then B, then C.
Why do you need them to be executed in a particular order?  Nothing about the 3 values are dependent on each other.  What else are you doing with these values besides incrementing them N times in the For Loop?
Message 14 of 22
(1,840 Views)
Hi Mike and Lucither,
thanks for your help! I am able to carry on with my vi!
thanks again!
cheers,
MC
Message 15 of 22
(1,831 Views)
The last vi i posted wouldnt of worked well, here is a better version.
Message 16 of 22
(1,828 Views)
How does that in any way look like the sketch drawn in message 5?
All of the proposed solutions show the shift register being used with the extra history terminals.  The sketch does not indicate that at all, and just shows 3 independent variables.
This is what the sketch shows.
And if this isn't what the OP wants, then he needs to adequately describe his problem.
Message Edited by Ravens Fan on 03-23-2010 09:37 AM
Message 17 of 22
(1,818 Views)
He does not want them incrementing at the same time. He wants one to increment only per iteration, thats why the history terminals are added. So they go in order, A then B then C then loop forever.
He also changed what he wanted from sketch 5 later on. he wants the last one to - 1 not + 1.
Message Edited by Lucither on 03-23-2010 08:43 AM
Message 18 of 22
(1,813 Views)
hi Guys,
Any way to set a delay btw each addition/subtraction ?
best.
mc
Message 19 of 22
(1,776 Views)
Hi YMC,
yes it's possible. You can use a state mashine. Create a case for every addition of one variable and min. one case for the delay case. Initialize your state mashine with the first case and jump then from case to case as needed.
Mike
Message 20 of 22
(1,772 Views)
