reen line, process variable value in a white line, maximum and minimum in red lines.Is there a way that I can change the process variable color only for those points when the values are out of max and min range and leave the in range points still in white?Greetings, Yurong:
Your best bet is to use the INTENSITY chart. It's a bit overkill for simply two color states, but it's very convenient. You set it up to plot x v y in the normal manner, but also direct your y data to the Z axis.... you can set any number of threshold colors as you want. Just another solution to consider!
Hope this helps
chutla
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
