Is it possible to use 2 monitors by using win nt for the labview? In the first I wouldt like to see temperature und pressure worths and in the second some diagramms and other process buttens.
I am not absolutely sure about NT but this works well
in Win98. Assuming of course that you have a video card with 2 outputs and it is "standard" (ie does not need special calls to the video board).
(2,693 Views)
There are outboard adaptors available for running several monitors; we used this technique way back in Win3.1.1 days when the resolution wasn't good enough to fit large Labview vi's on a single monitor. I'm not sure who manufactured them, but I'm sure there are upgraded versions.
Chutla
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,693 Views)
