I want Labview DSP hardware for program download
I want to know that wether the target specified for the Labview DSP module can be used in some other board by taking out chip from the hardware download board. Also I want to know how i can download the program created in Labview DSP module to the target chip. Is some hardware and cable available for this.
(2,419 Views)
Hi Ankit,
Please refer to the following KB to see which targets are supported by LabVIEW DSP.
http://digital.ni.com/public.nsf/websearch/AF9886D62684C05D86257101007F4647?OpenDocument
A USB cable is used to connect to those boards so that the user can download the code to the embedded target. Currently, the LabVIEW DSP Module does not support custom DSP hardware even if the hardware has similar or identical peripherals to the supported targets.
Hope that helps!
Kalin T.
(2,397 Views)
