disable a plot
If I have a waveform chart with 8 plots and I would like to stop plotting one plot while it is running, how would I do so?
(2,861 Views)
If you wire a NaN to the plot you wish to turn off, then it will appear as though it is turned off (though past data will still be displayed).
(2,856 Views)
Use property node of Chart ( properties 'Active plot' and 'Plot Visible?') as shown in the attached pic
Any doubts, do ask
Regards
Dev
(2,848 Views)
