I want smooth thermocouple signal
Thanks for reply
I have attached the VI , yes i just connect thermocouple to DAQ. and i follow the DAQ assist with selecting the Analog signalinput as thermocouple.
Except cool junction correction there i wasn’t find to enter gain
I am sorry I am new for this software just i am learning
danushka
Message 21 of 23
(1,122 Views)
instill,
Although the 6008 is not very good for direct thermocouple readings, you might try one thing: Set it up on the lowest (1V) range and for 10000 samples per second.  Then average the 10000 samples once a second.   This will give you a much more accurate signal that might be good enough for your purposes.
-- James
Message 22 of 23
(1,116 Views)
Are you convinced that you can't connect a TC directly to a USB 6008 device even if you select "Temperature" measurement?
If yes, then you should first propose how to solve that problem. Once this is done go on with the software and come back with questions about LabVIEW coding.
There's nothing wrong with your code so far.
Since the 6008 doesn't have a CJC, you set the CJC to a fixed value of 27°C, fine for me 🙂
If no, then we have a problem 😞
What other convincing arguments do we have here guys to convince instail ?Smiley Very Happy?Smiley Tongue?
Message 23 of 23
(1,114 Views)
