08-16-2009 11:40 PM
Hi!
I just try to measure the temperature in boiling water by using T- type thermocouple, Ni DAQ 6008 devise and labveiw 8.2 version.
I was work but there is a problem which the temperature it fluctuating ( so much variation) I want it to be smooth.
do I want to use amplification to input signal ?
If any one can help me it will be appreciated
thanking you
Danushka
08-17-2009
12:23 AM
- last edited on
10-29-2025
09:20 AM
by
Content Cleaner
Did you read this or this or this ?
All nice literature regarding TC measurements.
I don't think DAQ 6008 is good equipment to read TC's unless you have the right signal conditioning.
What is the standard deviation of your signal?
08-17-2009 01:26 AM
i do not know much abt this...but i think u must use filters..
also temperature regulator will do the whole job..
08-17-2009 01:30 AM
08-17-2009 04:53 AM
Thank you for your reply
stranded deviation around Degrees
I think I want to implement amplification and filtering because thermocouples generate low-voltage signals and are to noise.
I have no experience in this regard just because i am new to the labveiw
please help me
thanking you.
08-17-2009 05:02 AM
instail wrote:
Measuring Temperature with a ThermocoupleThank you for your reply
How many degrees? 1, 5, 10??
What do you expect?
You can consider to put one of these between the TC and the 6008!
08-17-2009 05:03 AM
08-17-2009 05:56 AM
Thank you for the reply,
i want mesure temperature, than i am thinking to graph itusing labview later i desided to implemetn temareture control systerm .
tempareture may be in between 25-250 C
2 C diviation is not much problem.
danushka
08-17-2009 05:57 AM
I want measure temperature, than I am thinking to graph it using labview later I decided to implement temperature control system .
Temperature may be in between 25-250 C
2 C deviation is not much problem.
danushka
08-17-2009 06:01 AM
