I want smooth thermocouple signal
Hi!
I just try to measure the temperature in boiling water by using T- type thermocouple, Ni DAQ 6008 devise and labveiw 8.2 version.
I was work but there is a problem which the temperature it fluctuating ( so much variation) I want it to be smooth.
do I want to use amplification  to input signal ?
If any one can help me it will be appreciated
thanking you
Danushka
Message 1 of 23
(4,782 Views)
Did you read this or this or this ?
All nice literature regarding TC measurements.
I don't think DAQ 6008 is good equipment to read TC's unless you have the right signal conditioning.
What is the standard deviation of your signal?
Message 2 of 23
(4,773 Views)
i do not know much abt this...but i think u must use filters..
also temperature regulator will do the whole job..
thanks
do not hesitate to give kudosSmiley Happy
Message 3 of 23
(4,762 Views)
sorry not temperature regulator..voltage regulator...so that small deviations are ignored..
thanks
Message 4 of 23
(4,762 Views)
Measuring Temperature with a Thermocouple
Thank you for your reply
stranded deviation around Degrees
I think I want to implement amplification and filtering because thermocouples generate low-voltage signals and are to noise.
I have no experience in this regard just because i am new to the labveiw
please help me
thanking you.
Message 5 of 23
(4,735 Views)
How many degrees? 1, 5, 10??
What do you expect?
You can consider to put one of these between the TC and the 6008!
Message 6 of 23
(4,729 Views)
Please post a snapshot of your measurement signal. It would be nice if you could post your schematics also
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 7 of 23
(4,728 Views)
Thank you for the reply,
i want mesure temperature, than i am thinking to graph itusing labview later i desided to implemetn temareture control systerm .
tempareture may be in between 25-250 C
 2 C diviation is not much problem.
danushka
Message 8 of 23
(4,715 Views)
I want measure temperature, than I am thinking to graph it using labview later I decided to implement temperature control system .
Temperature may be in between 25-250 C
 2 C deviation is not much problem.
danushka
Message 9 of 23
(4,714 Views)
Try this moving average filter.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 10 of 23
(4,705 Views)
