I want the PCI-MIO-16-E4 ad board driver file.
I am  doing research in aerospace department Anna university. i am using the hotwire annemometer. Data acquisition  purpose using the PCI-MIO-16-E4 AD board. The driver file of the board is corrupted. so request you to send the driver file.
thank you
(3,040 Views)
Hi!
   The board you're using is quite old, check for NI PCI-6040E (which is said to be "formerly known as PCI-MIO-16E-4").  So you should search for that drivers, the one for PCI 6040.  See the attached links:
   PCI 6040E
   traditional DAQ
   This board is supported also by Ni-DAQmx, which is a newer set of drivers. Check for LV and OS compatibility....
   But... just a question, how do you say that driver is corrupted? Do you have a message from LV, or whatelse?
   Hope I can help...
graziano
PS.: Just a note, post these kind of requirement under Data aquisition, or DAQ forums, there you can find exactly what you need!
(3,036 Views)
