System Exec use all resources system if "wait until completion" is true !
I use the function "System Exe" since a long time to launch various executables since Labview.
The " waint until completion " boolean is true, because I have to wait the end of the external executable to continue.
Big problem: the function " System Exec " use all resources system, by waiting for the end of the external program.
Is it a bug of this function ?
In my example, "System Exec" launches only the notepad (LV 8.2 on XP)
Thank you for your suggestions.
AC
AC
(3,210 Views)
That's a known issue that kind of has to do with the way Windows apps work. Use the "Run Application" VI from the lvwutil library. I think the "System Exec +" from that library will work just as well. The difference between the two is that the "Run Application" VI has a timeout.
(3,182 Views)
The way you use System Exec.vi is wrong.  See attached VI.
LabVIEW takes 0% resources on my laptop when waiting for Notepad.
George Zou
George Zou
(3,167 Views)
Thanks to both for your speed.
In fact I had simplified my vi to target the problem.
I use System Exec to launch another executable, made possibly with labview, but with passage of parameter. (Ex: - " / string:init ").
In the literature Labview it was made with the method cmd / x / c start by putting twice the path of the executable.
In this method a waiting time in the recent system exec function was effectively missing.
But effectively, today, it is enough: "c:\myexe.exe" - " / string.init " to launch and to pass a parameter.
You have both reason and I thank you sincérement.
Very cordially.
Sorry for my English....
AC
AC
(3,150 Views)
