Hello DSPGUY1,
You can definetly acquire from several channels. For your convenience, I have appended below the content from help that tells you how to configure it:
"channels specifies the set of analog input channels. The order of the channels in the scan list defines the order in which the channels are scanned during an acquisition. channels is an array of strings. You can use one channel entry per element or specify the entire scan list in a single element, or use any combination of these two methods. If x, y, and z refer to channels, you can specify a list of channels in a single element by separating the individual channels by commas, for example, x,y,z. If x refers to the first channel in a consecutive channel range and y refers to the last channel, yo
u can specify the range by separating the first and last channels by a colon, for example, x:y."
Hope this help.
Serges Lemo
