I want to add a series of random number in following pattern: (0.5(0.5(0.5x1+x2)+x3)+x4).... How to perform this in a while loop?
As asked in the subject, can someone tell me how to do it?
Message 1 of 8
(3,637 Views)
Will,
I would strongly suggest going through the 6-hour introduction to LabVIEW
http://www.ni.com/white-paper/5241/en/
I came up with a simple solution using shift registers to divide our previous iteration by two then add another random number and display that to the user.
Message 2 of 8
(3,629 Views)
This might have been a homework assignment. Smiley Surprised
Message 3 of 8
(3,627 Views)
The result seems not as same as what I want. What you have there are 0.5x1+x2, 0.5x2+x3, 0.5x3+x4.......Am I right?
Message 4 of 8
(3,616 Views)
Actually it is not. It is part of a project I am working on. I am struggling to convert from c to labview.
Message 5 of 8
(3,613 Views)
I think you may need to swap the order of the divide by 2 and the addition.  I would intialize the shift register with a zero.
But beyond that, it seems correct.  Remember the shift register takes the value to the next iteration.  The value going into the shift register is equivalent to each set of parentheses.
Message 6 of 8
(3,589 Views)
Accepted by WilliamSun912
Out of the first iteration we will see X1 because we initialized the shift register with a rand().  The following two functions result in .5X1+X2.  That value gets passed to the next iteration, meaning we divide (.5X1+X1) by two.  After the addition we will then have .5(.5X1+X2)+X3.  This is what you wrote but because the series does not converge you will need to decide whether you want to read the value before or after you add the next random number.
Both ways should result in the same series, but they will pass different parts.  In my example we pass .5X1+X2 then .5(.5X1+X2)+X3.  If we do it your way we will first pass .5X1 then we will pass .5(.5X1+X2).  If we moved the indicator in my example to right after the left shift register and the indicator in your idea between the addition and division, they should read the same value each iteration.
Message 7 of 8
(3,578 Views)
