I want to create multiple ICOn templates, how do I create that(LV 8.5 full prof ver)
I am working on relatively big project and need help in creating multiple ICON templates.
Like insturement drivers, I would like to create multiple ICON template based on function(Config, Test, Data etc).  I am using LabVIEW 8.5 Full professional version.
Chetna
Message 1 of 13
(4,641 Views)
Download Mark Balla's icon editor (here's an 8.5 version).
This allows you to create icon's with special colored banners and stores them in memory.
Ton
My LabVIEW Ideas
Message 2 of 13
(4,634 Views)
If you make a Library in the project, then the Library can have a common template for all VIs you put in it.
Jeff | LabVIEW Software Engineer
Message 3 of 13
(4,612 Views)
Creating library for ICON?  Can you please tell me how to do it?
Message 4 of 13
(4,609 Views)
If you use a library (LVLIB), you have the option to create an icon-template that overlays the icons in the VIs.
However you still have the OLD icon editor. I strongly suggest to use Mark Balla's editor.
Ton
My LabVIEW Ideas
Message 5 of 13
(4,599 Views)
If you're in 2009 it is the new icon editor.
Create a new Library in your project. Right-click on it and go to Properties. Under general settings there is an icon editor option.
Message 6 of 13
(4,581 Views)
I have LV8.5 Prof. Version.  I tried with ICON library but the default remains the same.  They are saved as .vi and not .ico.  Is that right?  By the way, I can't download the 8.5 of MB's ICON editor.
Thanks all!
Message 7 of 13
(4,579 Views)
O, I posted the wrong URL: here's the good one: http://lavag.org/index.php?app=downloads&module=display&section=download&do=version_download&id=118
Ton
My LabVIEW Ideas
Message 8 of 13
(4,561 Views)
Ton,
Sure it is a right link?  It is getsnippet rather than MB's ICON editor..
Chetna
Message 9 of 13
(4,553 Views)
Strange, very strange. I have no idea what LAVA CR is doing.
Well here is the link to the main page, all the way down there is a link to the 8.5 download.
Ton
My LabVIEW Ideas
Message 10 of 13
(4,549 Views)
