I want to design loop or counter for measuring the data...
I am facing one problem that if I want to combine two array then what should I have to do.
For example here in attachment I have attached one example vi in that I want table with two column, but when I run my vi then I didn't get what I want.
Will you please guide me how can I do this.
Thank you very much.
Message 31 of 33
(530 Views)
i think, i got solution......
Message 32 of 33
(526 Views)
I want to update XY chart at same time of measurement.
Normally graph is update in last after taken all the reading.
And one more thing that how can I set OK button in such way that I do not need to press it two times means once I press OK then it will reset again.
Here in attachment I have attached one example Vi which is similar to my actual program.
Will you please guide me.
Thank you very much.....
Message 33 of 33
(506 Views)
