I want to make it save a new text file every second.
I created it like this, but I want to make it save a new text file every second. After that, I intend to load the results into MATLAB and plot the graph. How can I achieve this?
(1,177 Views)
Accepted by topic author wnsl7063
Just give a new name for every new file, something like this and append to base path by Build Path:
(1,158 Views)
Thank you, sir!
Although it is functioning, there is an issue where only one file is being generated. How can I resolve this?
(1,118 Views)
If you probe the wire going to the file write loop i'll bet it only has 1 element. Also, if the outer loop spins you'll start from 0 each time overwriting it. Maybe you want to name if after the timestamp?
Qestit Systems
Certified-LabVIEW-Developer
(1,112 Views)
Thank you, sir
I just want to make file0, file1, 2, 3 every second.
So how can i make it?
(1,090 Views)
Hi wnsl,
@wnsl7063 wrote:
I just want to make file0, file1, 2, 3 every second. So how can i make it?
Use the CreateFileWithIncrementingSuffix function to create unique filenames!
(1,082 Views)
