Issue with external code LabVIEWHTTP.lvlib
Hello LabVIEW-Community,
I recently took over a (nearly finished) LabVIEW project, which has some issues. It's rather big project where there are also some huge parts that are unused (or rather used in at different teststup). Gotta say that I'm new to LabVIEW and only been working with it for 3-4 months.
The structure is that of a big producer consumer loop although there are some VIs in the Toplevel (main program) that contain consumer porducer loop. It was done this way for a slightly different product. Is this actually a problem?
Well after initializing the devices (3x DMM, 2x source, 1x function generator) I got the error 23 on for some VIs. One of which uses LabVIEWHTPP.lvlib and there's some issue with the external code. Are these even related to the code or is there maybe an issue with the computer (too less RAM or memory availabele)? As I got more of the same errors for different VIs. Is there any possible solutions how to fix this?
PC spec:
Win 10
processor i5-4570
harddrive 250 GB
RAM 16BG
Thanks a lot!
Laura
Message 1 of 1
(1,098 Views)
