I want to pause a vi.
I want to pause a vi.It has a while loop and inside it some subvis that are running.I don't want to pause it from the 'PAUSE' button that is located in the toolbar.
(3,003 Views)
In order to pause a VI without using the 'PAUSE' button, you will have to send your program into a continuous loop and quit the loop when you want your program to resume execution.
I have put together a quick example that demonstrates how to do this. Hope this helps!
(3,003 Views)
