I want to put some data in a buffer
Hi. I'm Sorin.
I aquire data at 2 sec, and i want to put the numeric values in a buffer to compute the maximum value. How can i do that, or what functions should i use ?( for buffer and maximum). Or, is it another way much simple that that ?
Thank you.
(2,808 Views)
Hi Sorin,
you can aquire your data in a loop and use shift registers to store your data (use an array). To get the maximum of the array there is a function in labview "Array Max & Min".
Hope this helps.
Mike
(2,802 Views)
As said use a shift register. But the max value can be calculated in every  iteration, so no need to store an array if you don't need the data, farther.
(2,791 Views)
