I want to synchronize my motion position with data acquisition
I have PCI-7344 and PCI-6023E and I want to synchronize them so that my DAQ card will start and stop the acquisition definitely when the motion start and stop. Also I want to acquire velocity and the data from DAQ card in the same scan rate. Thank you.
(2,700 Views)
Greetings,
You will synchronize your PCI-7344 and PCI-6023E through the RTSI bus which is available on each board. The manuals for the PCI-7344 and PCI-6023E give more specific information regarding which signals need to be routed through this bus. There is also a tutorial available which discusses synchronizing motion and data acquisition which I have attached below:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/66e6f4ee7e0848d686256a550060c436?OpenDocument
Good luck with your application.
Spencer S.
(2,700 Views)
You need to have the PFI0 and PFI1 of the 6024E to sense a transistion for a Start and a Stop. I have been succesful doing this on a 6602 Timer -6024E DAQ card at least in going from one direction (CW). The 6602 can have an encoder input in which you can code a velocity measurement VI or this may also be present on 7344 card? I have attached my debug version that has worked on my optical bench for your reference.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(2,700 Views)
