I want to thin out the data that is being read 1000 elements at a time.
Hi Ikeda,
@ikeda_kaoru wrote:
I have one more question!
I made some improvements based on the program you gave me, but I could not connect the wires.
It is where I connect the 1D array data coming from the FIFO to the Index Array in the For loop.
I am attaching an image and would appreciate your advice.
Unfortunately your image is stucked in virus scan, but I guess you forgot to change the input tunnel mode for the array wire…
Message 11 of 22
(775 Views)
@ikeda_kaoru wrote:
@Yamaeda さんは書きました:
@ikeda_kaoru wrote:
Hi  LVNinja
Thanks for your reply!
I have checked the attached program.
I ran the program with 1000 arrays and 198 to extract, but the Array Indexes to extract indicator shows 0,198,396,594,792.
990 should also be output, but why is it not?
Since you also extract index 0 you get a 1-offset issue, which is quite common. Modify the VI like this:
(The round towards -inf is to make sure it doesn't round up so you get 1 too many extractions)
Hi Yamaeda
Per default an array passing into a For-loop gets Auto-indexed. R-click the little [ ] on the border and turn off Auto-index
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 22
(757 Views)
@Yamaeda さんは書きました:
@ikeda_kaoru wrote:
@Yamaeda さんは書きました:
@ikeda_kaoru wrote:
Hi  LVNinja
Hi Yamaeda
Thanks for the advice!
It worked.
I am trying to save the data (data read 1000 elements at a time) as a binary or CSV file before taking the 198 intervals.
I concatenate the x,y,x values of the data using the “Build Array” function and put them into a case structure.
How can I improve it so that I end up with 3 rows and 12976128 columns of data to save in the file? (3 rows are x,y,z values, 12976128 columns = 198 x 256 x 256 number of data)
Any good ideas would be appreciated.
Message 13 of 22
(750 Views)
Hi GerdW,
@GerdW さんは書きました:
Hi Ikeda,
I fixed it and it worked!
The program for the relevant section is attached.
Message 14 of 22
(746 Views)
@ikeda_kaoru さんは書きました:
@Yamaeda さんは書きました:
@ikeda_kaoru wrote:
@Yamaeda さんは書きました:
@ikeda_kaoru wrote:
Hi  LVNinja
Hi Yamaeda
It worked.
I forgot to attach the program for the relevant part.
Message 15 of 22
(742 Views)
Hi ikeda,
Nope, you didn't attach any code. All we got is an image: we cannot edit/debug/run images in LabVIEW!
Suggestion: instead of saving to a ".bin" file you should use TDMS functions instead! They allow for proper handling of additional information together with your data. (Excel isn't able to handle 12976128 rows or columns!)
Message 16 of 22
(723 Views)
@GerdW さんは書きました:
Hi ikeda,
Thanks for the advice.
I used the TDSM function to get the data. How can I check the data in the file?
The program and images of the relevant sections are attached.
Message 17 of 22
(698 Views)
Hi ikeda,
you REALLY need to learn to create CLEAN code! Use more (or any) subVIs…
Example:
You can use the TDMSFileViewer function to load and visualize TDMS data…
Message 18 of 22
(693 Views)
When saving binary data, I get the following error.
I do not know the cause and would appreciate your advice.
Message 19 of 22
(621 Views)
Hi ikeda,
Provding an image with mostly Japanese text doesn't help us to help you.
Mind to share English information?
Message 20 of 22
(599 Views)
