I want to update the Numeric Control at the press of a button
@bobholmgren wrote:
What I mean is I want the program to do literally nothing (except get data and graph it every 3 seconds using while loop and time delay) unless an input changes. Then I want it to run through once.
If you spin the loop anyway, don't worry about executing this part of the code with every iteration. it is insignificant in the grand scheme of things.
Message 21 of 28
(1,306 Views)
I'm unsure how to have my program run essentially continuously with the inputs as "interrupts" to break it out of the loop and run the rest of the code, then re-enter the loop again.
I'm not used to labview (Only been using it a couple days)
Message 22 of 28
(1,299 Views)
You don't need to break out of the loop. Place all the controls in the main loop and they will get polled once per iteration.
Message 23 of 28
(1,280 Views)
Ok, I just did a while loop with everything in it, and a .2 second delay (data will only need to be recorded once every 30 seconds or so).
Now it loops and rechecks everything once each time that the time delay is over.
Thank you
Message 24 of 28
(1,269 Views)
Give Altenbach a Kudo and mark his solution as the accepted solution.
- tbob
Inventor of the WORM Global
Message 25 of 28
(1,265 Views)
Which solution should I mark? haha.
My question evolved and changed so many times.
Message 26 of 28
(1,263 Views)
Mark the one that solved your original question.
- tbob
Message 27 of 28
(1,257 Views)
@altenbach wrote:
Now, to solve your programming issue, you would:
My excuse is that I misinterpreted the full extent of the question.
Message 28 of 28
(1,220 Views)
