I wantto amplify analog input coming from the channel, and I am using DAQ board and LABVIEW
We are measuring voltage in millivolts and we are trying to amplify our input and sample data between 3-10 milli volts
(2,511 Views)
Change the gain setting. If you look at the help for the VI you're using for the acquisition, you'll see the definition of the high limit and the low limit inputs. Leaving them at zero means that the gain defaults to whatever you've set in MAX. You can change the range in MAX or specify it in your VI.
(2,511 Views)
