how can i localize value in table
i attach file,i want to make values in table after i can localized it to use it
for example i want a11 first line and fist row
a12 fist line second row
(2,615 Views)
I an not sure what you are trying to do. Are you tring to put a text file into a table in LabVIEW? If so, here is a simple example that should illustrate this.
(2,615 Views)
