I was trying to use the Matlabscripting VI, but it says it is for instructional purpose and not for research and the system is getting stuck.When I used it two days back it worked.Could U plz tell me what the problem is??
I have Labview 7.0 and Matlab 6.5 installed on all the computers at my School. When I tried to use the Matllab Scripting Window for the first time, it worked, but after two days when I was trying to run the program, there was a meesage saying that the License is for instructional Purpose only and not for Research or commercial use and the Labview is getting totally stuck. I need the Matlab Scripting VI for my Project,could anyone suggest what I shd do or is there any other method by which I could do that.
(2,513 Views)
Hello Medha,
Thank you for contacting National Instruments.
From the information you have provided, I am not sure what is causing your problem. Make sure that you do not have an evaluation license for LabVIEW.
What, if anything, was changed in your VI before it stopped working? Will it run without the Matlab script?
If you continue having trouble getting your VI to work, please respond with more information. If you like, you can post your VI (along with any necessary sub-VIs) and I will take a look at it.
Have a great day,
Sean C.
(2,513 Views)
Hello Sean,
Thanks for the reply, the problem has been solved by replacing the Matscript.dll in the scripts folder.
Medha
(2,513 Views)
