Open vi reference problems in labview 7 after building an application
I have a vi with an Open VI Reference vi in it.
This works fine. But when I build an application of it and run the vi it gives problems.
I get an Open VI Reference error. Why?
(2,967 Views)
If you have strict typedefs for the dynamic loaded VIs you need to include the line "BldApp.RemovePolyVIsandTypedefs=False" into your LV ini file. See this discussion.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,967 Views)
Are you taking into account that the path to a VI is different in a built app?
(2,967 Views)
Dennis,
I always forget this because it is so self-evident (I hope the word is right) for a experienced programmer.
You should send me a bomb if I do it again.
Waldemar
Waldemar
(2,967 Views)
If I had a dollar for all the things I forget and assume each and every day, I could retire soon. One of the hardest thing about this forum is judging the experience level of the person posting the question.
(2,967 Views)
Hi Richard,
Please take a look at the following documents:
Error 1003 When Using VI Server in a LabVIEW Application
Cannot Call SubVIs Dynamically that Are Not Included with LabVIEW Executable
I hope these documents help. If not, please provide more info on what error you are getting.
Feroz
(2,967 Views)
