I would like to define a default printer in Labview. How could i do that? could someone help me?
best regards
H.A. Brosi
(3,863 Views)
See what Vix says. He made an example.
http://forums.ni.com/ni/board/message?board.id=170&message.id=133336&requireLogin=False
It's the last post.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,858 Views)
Here is another VI. I'm not the author and the diagram is unfortunately password-protected. Please notice that it will work with W32 only.
(3,852 Views)
Thank for your helps
Kind regards
H.A. Brosi
(3,825 Views)
hello all
Thanks for your .VI
but still have a problem on my using.
Printer name:
  DATAMAX I-4308   and set as default printer
i want to set the size of the printer,
and it can be setted,but actually it have no active.
pls could you help me~~~~
thanks in advance~~~
(3,704 Views)
sorry for my fault
i want to set the size of paper ,so that i can control the printer the size of page
through vi front panel rather than windows NT/XP set
(3,703 Views)
Attached VI may solve your problem. Again, I'm not the author of the code.
(3,683 Views)
