PDA for rs232 communication--Recommendations?
I am looking for a PDA on which I can do RS232 communication.  Any recommendations?
I will be using the LabVIEW PDA module, and the documentation says that using the VISA drivers is not a problem.  However, the PDAs that I have seen so far do not explicitly mention if they have the hardware necessary for serial RS232 communication.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(4,579 Views)
Hi S G,
There are several recommendations in the threads entitled Labview PDA using RS232 and Labview PDA Palm devices supported
How Do I Use Serial Communication on My PDA? discusses the option of using a Compact Flash card.  You may also be interested in Using a Bluetooth Virtual Serial Port
Hope this information helps.
Jennifer R.
(4,472 Views)
