Hi there,
I tried the Remote Panel Login examples which were attached by Zvezdana S. It works when main.vi running in Labview enviroment. But after I created a executable file of main.vi, it didn't work, the Web Server: Browser Access couldn't be changed from "remote panel loging.vi". BTW, both main.exe and Remote Panel Login,vi run at the same PC.
I am confused by ports number, ini file.
How could I set port number when they are running at the same PC?
When I built the executable file, ini file was built in as a support file. should ini file be changed on fly when you change Tools->options setting at executable.
In Remote Panel Loging.vi, there is a application property node, do I have to reference it to localhost?
Thank you very much for the reply.
