I2C Communication using FT2232HL in LabView : Read Error
I am using FT2232HL to communicate with an I2C device.
I am using the MPSSE I2C API calls.
I am able to successfully Write to the device. Both my GPIO Read and Device Read does not work.
I am able to observe the scope timing, and the Read Data is correct. it is just that when I call the function in LabView, it always shows up as FF. Same for GPIO Read as well.
I am using LabView 2013.
Thanks for the helps.
Message 1 of 11
(5,539 Views)
Can you provide more information about the issue you are having, like the configurarion on VISA.
 There ir a forum that explains a simular issue and it can be related with the VIS configuration:
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Reading-IMU-via-RS-485-Output-Missing-Packet...
Message 2 of 11
(5,491 Views)
Thank you for the response.
I was able to investigate a bit further.
Now, I do not see the "FF" read error. But something more strange.
I have a successful Write to slave and a Read from Slave if the register does not contain "0x00__".
Included the screenshots of 2 different scenarios:
1. Register read when the data is not 0x00_ _ .
2. Register read when the data is 0x00_ _.
The third screen shot is the Read_Device driver API VI. everything seems to be working except reading the default data of "0x000098"
Thanks for the help.
Message 3 of 11
(5,478 Views)
can someone please comment on the above issue reported?
Message 4 of 11
(5,428 Views)
Your Call Library Node needs to pass the data as Pointer to an Array of U8. When you configure it as a C String Pointer, LabVIEW will on return terminate the string on the first 0 byte it encounters in the string. This is because C strings are by definition terminated by a 0 byte. If you want to pass a binary buffer to a DLL that can return NULL bytes in it, you need to pass that buffer as Byte Array!
Rolf Kalbermatter  My Blog
Message 5 of 11
(5,417 Views)
Hi Rolf,
Thanks for the response.
Is this a change required in the DLL file itself.
Because I am not able to connect anything other than String to that node.
It shows a source and sink mismatch error. The input to the Buffer node is String.
Is there anything I can do to alleviate this problem?
Ashwin
Message 6 of 11
(5,407 Views)
Accepted by topic author Ash.Bad
You need to change the data type inside the Call Library Node configuration for the uint8 *buffer parameter. It is now configured as C String Pointer but you need to configure it as Array of Unsigned 8 Bit Integer, passed as Array Data Pointer.
Then you can also throw away the Byte Array to String and String to Byte Array nodes.
Message 7 of 11
(5,401 Views)
Hi Rolf,
Thank you for your inputs. I was not aware that I could configure the datatype on the call library node.
I works great now. I appreciate your help on this.
Regards
Ashwin
Message 8 of 11
(5,390 Views)
PLS send me your code to ilanmazuz4@gmail.com
thank you.
Ilan Mazuz
Message 9 of 11
(4,514 Views)
Can you please explain how did you get rid of the "FF" while reading from slave? I am facing a similar issue with FT232H device and the MPSSE I2C library.
Thank you in advance.
Message 10 of 11
(1,481 Views)
