I2C montior, sniffer, 8451
Ok I hope this is a quickie. Anyone know if it's possible to create an I2C sniffer using a USB-8451?
If not, any suggestions for the easiest way to do this?
Thanks, Ted
(3,460 Views)
Unfortunately, the 8451 only functions as a Master device.  Take a look at the following forum post for a bit more information:
http://forums.ni.com/ni/board/message?board.id=170&message.id=203809&requireLogin=False
Chad B. » National Instruments » ni.com
(3,433 Views)
Yeah I know. But I just want to watch the I2C chatter between another master and slave.
Can't do this with the 8451 hmmm?
Thanks, Ted
(3,416 Views)
U can use a digital input.
u take the SDA data at each rising edge of scl and u can check the datas like this:
adresse, ack, request, ack
try it
i used a PCI-6220
Message Edité par ezraal1 le 08-28-2007 10:21 AM
(3,380 Views)
