ICP (IEPE) Load cell data aquisition with external excitation source
I am getting 4431 for my test stand.
I've tested my signal using a loaner 9233 from one of NI's Field Engineer. 9233 has limitation of 51ks/s/ch.
Thats why i m getting 4431. I hope 4431 and 9233 behave similor.
Thank you jason for your support.
One more question -- I am sorry for adding into the same thread.
How do i acquire two signals coming from 9233 and 9215 to have same time base?
Ganesh
Message 11 of 12
(905 Views)
Accepted by meetgsl
Ganesh,
That is a whole different can of worms.  I suggest you create a new topic (I am not opposed to helping you out there).  Basically I would suggest you look at:
1) Multi-Device Sync-AI and AO-Shared Timebase & Trig-DSA.vi example program
This is a very complicated example but gives you a rough idea of what might be required.  If these 2 modules are in the same chassis I believe this is much easier.
Sincerely,
Jason Daming
Applications Engineer
http://www.ni.com/support
Message 12 of 12
(902 Views)
