IDDC error Keithley 2000
Hi all,
I have a command problem with Keithley 2000 DMM by using LV 8.6. Namely, even by using of the drivers downloaded from NI site, i can not initialize the DMM displaying error 961 on the screen.
I tried to communicate via M&A explorer, and  i send *IDN? query it responses the same error at the first time and when i perform the IDN query second time it doesnt give an error. I have no idea whats going on.
any help is appreciated.
Message 1 of 12
(6,164 Views)
And what does the error 961 mean?
Christian
Message 2 of 12
(6,160 Views)
Hi Christian,
it refers ''illegal command option''.
Message 3 of 12
(6,154 Views)
Sorry it was not complete, to be precise it is :IDDCO error.. (illegal command option)
Message 4 of 12
(6,151 Views)
Where you able to communicate with the instrument in MAX?
Christian
Message 5 of 12
(6,142 Views)
yes i m able to communicate with MAX.
Message 6 of 12
(6,136 Views)
I guess you have to communicate via RS232, please check the configuration then.
There are several other threads where people successfully communicate with this instrument via the instrument drivers.
Also check if you installed the right one, or maybe try another one.
Christian
Message 7 of 12
(6,130 Views)
There are two plug and play drivers one of which is project style. They would be different?
Message 8 of 12
(6,126 Views)
I don't know both of them because I don't have the hardware to test.
Did you also search for a driver via Tools>Instrumentation>Search for Instrument Driver?
Whats going on with the serial configuration?
Christian
Message 9 of 12
(6,116 Views)
You should also look into the K200's firmware version and installed options.  Unless this is a new device that you just got.  I've seen some odd behaviours with some older units that did not recieve updates from Keithley
Message 10 of 12
(6,108 Views)
