 XWX
			XWX
			01-26-2012 11:43 PM
I downloaded the Ueye software for Labview and installed it. I had made a VI using the Ueye API and everything was still fine.
But whenever I open my VI which contains API of Ueye application, I get requests to locate Ueye_api.dll
However when I looked in system 32 folder ( where it was supposed to be), it could not be found.
I tried searching this dll in my C drive, but it was still could not be found.
Now my Ueye API in labview cannot executes and I am stucked, is there anyway to locate this dll or is there any other way around it?
Much help is appreciated
XWX
Solved! Go to Solution.
 rolfk
			rolfk
			01-27-2012 01:55 AM
Reinstalling the driver is the first course of action with such problems. Seems the file has gone somehow from your system. How that could happen would be another interesting question, that nobody else but you can answer.
01-31-2012 08:46 PM
Thankyou for your help.
I installed the driver and it worked. I am new to programming and I appreciate your help!
