IEC 61850 GOOSE Protocol setup
Once again, thank you so much three lions, you have significantly helped me figure this out!  I truly appreciate it.
Andrew
Message 21 of 23
(1,717 Views)
HELP!
I cannot run the Publisher.vi, because i got this error:
Error -36115 occurred at Property Node (arg 1) in _CreatePublisher.vi->Publisher.vi
Possible reason(s):
Failed to find adapters. Possible reasons: no adapter exists on the target; the IEC 61850 is not properly installed.
What could it be?. Anyone has the same error, and how can i solve this?
Message 22 of 23
(1,539 Views)
Hey Alvaro,
I might suggest creating a new thread, rather than adding onto this thread which is largely resolved. There may be some good information relating to your topic, so linking this it is encouraged if you feel the information here is directly relevant.
A starting point for your new post may be to include some of the steps you have tried to diagnose the problem up to this point (i.e. reinstalling the IEC 61850 Driver and confirming that you have done so properly with respect to the installation instructions in the readme). Additionally, including your hardware and software setup as well as what you are hoping to do in your project would be useful.
Best of luck with this!
Sam R.
Message 23 of 23
(1,520 Views)
