IMAQ Histogram doesn't work
In the example that follows the IMAQ Histogram block doesn't do its job: all statistics are 0.
Where I've been mistaken ?
Thanks in advance.
(4,782 Views)
Well, look at the wire connected to the input of the Histogram Function -- it comes from an IMAQ Create function that creates a blank image!  So you get the Expected Answer, every intensity is zero.  Fix your wiring.
(4,775 Views)
Accepted by Pavel_47
Resolved.
The problem was the IMAQ Histogram doesn't work with RGB (I used PC web camera).
Workarounf: insert the Customizing function (that transforms 32-bit RGB to 16-bit grey) between ROI image and Histogram.
(4,768 Views)
Dear Sir,
         I am facing the same issue with IMAQ Histogram block I am not able to properly plot the Histogram for my 16-Bit Monochrome image. Can you please do share with me the solution you have found for sorting out this issue.?Hist.PNGHist.PNG
(3,963 Views)
