IMAQ Image to DLL
I want to pass an IMAQ Image to my Visual C++ DLL. For testing purposes is tried the imaqGetImageSize function, but I always get the error message "not an image". Here is my code:
#include "stdafx.h"
#include "image_test.h"
#include "extcode.h"
#include "nivision.h"
IMAGE_TEST_API long readEndpointImages(const Image **test, int *xRes, int *yRes);IMAGE_TEST_API long readEndpointImages(const Image **test, int *xRes, int *yRes)
imaqGetImageSize(*test, xRes, yRes);
return imaqGetLastError();
In LabVIEW I call the DLL via the Call Library Function, there I pass the image as "Adapt to Type" and "Handles by Value". The other variables are passed as pointers to 32-Bit-Integer...
What am I doing wrong?
Daniel
(3,695 Views)
Hi, Daniel,
Please read this:
http://forums.ni.com/ni/board/message?board.id=200&message.id=16579
You will found answer in the middle of the discussion.
Andrey.
(3,675 Views)
Hi Andrey,
thank you very much, this is exactly what I'm looking for. But what is this for a symbol between the "IMAQ SetImageSize" and the "Call Library Function Node"? I can't find it 😞
Daniel
(3,655 Views)
This is IMAQ Image Datatype to Image Cluster.vi. This SubVI is not present in the palette,
located in <Program Files>\National Instruments\LabVIEW x.x\vi.lib\vision\DatatypeConversion.llb
Andrey.
(3,652 Views)
THANKS!!!!!
(3,649 Views)
