08-02-2012 08:16 AM
I'm trying to read from an image various lines of text which are placed in different areas of the image.
So far I have used for each line a different OCR read text vi with different ROI descriptor.
Is there a way to to use only one OCR read text vi for all lines and make the block diagram more look more elegant and the application run more effectively?
Do I really need to use 20 OCR read text vi's with 20 recatangles for reading 20 different lines?
Shahar
Solved! Go to Solution.
08-02-2012 08:39 AM
As far as I know - no, its impossible.
Otherwise you don't need to put 20 OCR Read instances on the BD - you can do it with "for loop" with 20 iterations.
08-03-2012 01:50 AM
Hi Shahar,
As Andrey said it's not possible to have on OCR for several lines - just one per line.
Christian
08-06-2012 05:14 AM
Thank you Andrey and Christian. As you suggested I used a for-loop.
07-13-2013 01:18 AM
what all should we include within the for loop ? does for loop assign an roi for each line? can u pls post your VI reading multiple lines ?
