IMAQ P-i-P? Any premade .VIs?
Hey everybody,
Has anyone made a picture-in-picture .VI using IMAQ?  I need a VI which will take two live CCD feeds and put them in the same image window, one in the top right corner while the other uses the entire image screen....  same thing you'd see on a picture-in-picture TV.
Just checking, 'cause otherwise I'm going to have to write it (which I've already assumed I would have to)... just trying to save some time.
Thanks!
Jonathan
(2,892 Views)
Sound like fun.  Are you going to post your solution when done?  I would like to see it.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,885 Views)
from the lack of replies I figure nobody here has done it already.... yeah, I'll post it when I'm done.
(2,882 Views)
Have you tried playing around with the IMAQImageToImage VI?  It sounds like it will do pretty much what you are looking for.
S. Arves S.
(2,875 Views)
Ok... apparently I'm a dumbass.  You are right, IMAQ already has an 'image to image' function which allows you to do a picture in picture just as I wanted.
Though, for everyone else here's a super simple way to make it work
(2,864 Views)
